Shocked
  • November 29, 2010
  • 11 replies
  • 2196 views
I have been using my custom "Regen until complete" program and I find
it so useful that I am shocked PTC does not have this as built-in
functionality.
Does no one else find it annoying to have to press the regen button
multiple times to get a complete regeneration of a complex model?
    18-Opal
    November 29, 2010
    Personally, I have always viewed having to regen multiple times as a sign of something being wrong.... A CRC for example. With the ability to move relations to the footer in recent releases, even more so.
    -marc
    The only times I've seen the need to regen more than once is when there's a
    confusion of external references (where parents are dependent on children
    for geometry and/or placement, and vice-versa); and where relations are out
    of order. If you keep your modeling in a parallel manner (as in top-down)
    rather than serial, regen once should be all you need. But I agree that
    Pro/E should be able to give you more of a warning/explanation if there's a
    regen problem.
    David Tate
    Keystroke Designs,
    Kelowna, BC, Canada
    250-763-6633
    250-212-9339 cell
    I'm with you Marc,
    My initial thought on this was that it was something where the user is
    pressing the envelope of Pro's capabilities, but I have never run into a
    situation where multiple regens are needed unless I don't have the
    relations sorted or there is a CRC.
    I'd be interested in an example where this is the case.
    Bob Frindt
    Sr. Designer
    Parker Hannifin Corporation
    Parker Aerospace
    Gas Turbine Fuel Systems Division
    8940 Tyler Boulevard
    Mentor, OH 44060 USA
    direct (440) 266-2359
    cell: (216) 990-8711
    fax: (440) 266-2311
    www.parker.com
    Marc DeBower <->
    11/29/2010 03:20 PM
    Please respond to
    Marc DeBower <->
    To
    cc
    Subject
    [proecad] - RE: Shocked
    -marc
    Site Links: View post online View mailing list online Send new post
    via email Unsubscribe from this mailing list Manage your subscription
    Use of this email content is governed by the terms of service at:
    privileged. It only should be used or disseminated for the purpose
    of conducting business with Parker. If you are not an intended
    recipient, please notify the sender by replying to this message and
    then delete the information from your system. Thank you for your
    cooperation."
    lococnc1-VisitorAuthor
    Interesting.
    I have many models which we consider "universal" They are setup to adapt
    themselves to many design variations. Quite complex. Pro/E does not fully
    regenerate all dimensions using the regen button. It knows that they need to
    be updated but it just doesn't do it. The order of the relations may have
    something to do with it, however we have to group a bunch of things under
    IF-THEN-ELSE statements to bring about the variation. I suppose I could
    seperate some of the stuff into later IF statements but it would make it
    almost impossible to make changes to the structure.
    All,
    CRC's and out of order relations aren't the only reasons a model might need multiple regens. We use flexible components in our deployable assemblies in order to show them in different positions. For example, we frequently need to show a model in different states in different views on the same drawing. When sub-subassemblies have flexibility more than one regen is needed to propagate the flexibility to all the right models.
    Michael, Can I get more info on your custom "Regen until complete" program?
    Mike Foster
    ATK
    Hi all,
    When creating a new drawing, we currently choose a template (inch or metric), which opens the drawing with the rectanglular border. The drawing is then created, and at some point add a format gets added to it. The title block info is driven by part parameters and the drawing rev and release level is driven by Intralink. We plan on having the same setup when moving to 9.1
    An option being considered is to combine the template with the format so that the format comes up and doesn't have to be added. Is inserting a format after the fact poor practice, or is it more flexible?
    Curious as to what others are doing.
    Stefan
    Hi Stefan,
    We only have to deal with metric so need less choice. We have templates for
    A4 through to A0 and each of these calls in a format of that size. The
    format has all the titleblock variables automatically filled in from
    parameters in the part or assembly. These show as default values if the
    parameters have not been updated in the part/assembly. This also covers use
    of ISO tolerance classes in the titleblock. We use the same format for
    every sheet in a drawing so this ensures they all have the correct
    information.
    Works really well.
    Regards, Brent Drysdale
    Senior Mechanical Designer
    Tait Radio Communications
    New Zealand
    DDI +64 3 358 1093
    www.taitradio.com
    Stefan,
    we keep template drawing and formats separated for maintenance reasons.
    If you need to change a config.dtl option you will have to do that on
    every template drawing as it is stored there.
    A change to the format is the same amount of works in both use cases.
    /Bjarne
    "Mueller, Stefan" <->
    30-11-2010 22:11
    Please respond to
    To
    cc
    Subject
    [proecad] - Detail files and formats
    Hi all,
    when moving to 9.1
    Stefan
    Hi Stefan,
    In order to drive the title block info using part parameters you need to add the format to the drawing after the part model has been added to the drawing.
    Otherwise those model parameter expressions convert themselves to look for a drawing parameters of the same name - they essentially add a ":D" to themselves. For example "&proi_revision" turns itself into "&proi_revision:d" and displays the drawing revision instead of the model revision which is very irritating.
    Drawing templates are supposed to save users from carrying out repetitive steps but they don't do it very well for those who want model parameters to drive their title block information. Pro/E has always had this nonsensical functionality and they didn't fix it when drawing templates were introduced a dozen or so years ago. Nothing has changed in Intralink 9.1.
    We wound up changing our formats to display drawing parameters rather than model parameters which PTC suggested is the right way to use templates.
    Mike Foster
    ATK
    We use Intralink 9.1 and drawing templates (WF 4.0). It isn't easy, but it is possible to link model parameters to the drawing parameters. For example, the description of the drawing is automatically the same as the description of the part.
    TPI 114055 will get you started.
    You can go to tools, drawing program in the template but the first trick is there needs to be a dummy model in the template. When youÂ’re done writing the program, remove the dummy model from the template drawing.
    The other trick, is the driving parameter must not exist in the template. It has to be created by the drawing program at the time the model is added. You may need to delete the parameter from the template or the dummy part before you write the program.
    And the next trick; if the parameter does not exist, it canÂ’t be declared. It is important to declare the parameter so that it can be shown in intralink browsers. The only way I could figure out how to do it is to use 2 equal parameters in the part model. The driven parameter exists in the template, and is declared. The driving only exists in the part, not the drawing.
    Part relation:
    Title1=Description
    Drawing program: Description is declared, title1 does not exist.
    Description:D = title1
    Last trick, once you remove your model from the template, it can freeze your BOM table. Re-insert the table.
    I said it wasnÂ’t easy.
    Erik
