Feb 4, 2015 2:24 PM UTC
Showing Mass Properties analysis in the Model Tree
I'm hopfull someone can help me with this. I've tryed asking tech-support, althougth he was very helpfull we were'nt able to get this working. When I run a Mass Properties analysis it doesn't show in the model tree. I have run the analysis about 6 or 7 models and the analysis shows up in the tree, but now the analysis will not show up on newer model and analysis.
Thanks in advance for any help
    Mahesh_Sharma
    22-Sapphire I
    Feb 4, 2015 7:15 PM UTC
    Chuck,
    Analysis results will create a feature in model tree, if Results were computed using option "Feature". Results with saved analysis will not create any feature in model tree, saved analysis can look in "Saved Analysis" under Analysis tab. If required, you can create features of saved analysis, Analysis > Saved analysis > Select the saved analysis in list > Select "Create feature of Saved analysis" (Second icon in bottom of saved analysis) > Enter name for analysis feature, this will create a feature in model tree.
    Feb 4, 2015 7:41 PM UTC
    Mahesh,
    I am not sure, whether any Creo license enables user to create analysis feature. It seems to me that some specific module must be present in the license... Do you know which one is it ?
    Martin Hanak
    Mahesh_Sharma
    22-Sapphire I
    Feb 4, 2015 8:21 PM UTC
    Martin,
    Limitaions in Analysis will needs Behavioral Modeling Extension
