2-Explorer
Feb 6, 2012 7:40 PM UTC
Simplified Reps and Hiding On-Screen Overlay
I'm relatively new to Creo, although I have quite a bit of history with Pro/E in the release 2001 timeframe. I'm working with some simplified representations and attempting to save some screen shots (File > Save As > ...) of various states. However, the overlay that says "On-Demand Simp Rep: XXXXXX" is always hovering there and comes out in the screen shots as well. Is there any way to hide this overlay temporarily while I am making these images?
Adam
    Feb 7, 2012 7:31 PM UTC
    Do you need an image of the entire screen? You could crop your image or you could make a snapshot of the just the area that you want with program that I've attached. Its an executable, no installation required. Just unzip the file and start using it.
    2-Explorer
    Feb 7, 2012 8:03 PM UTC
    From an image quality standpoint, I would prefer the entire screen. I have been cropping the images thus far to remove the overlay. I'm just curious as to whether the overlay can be turned off readily. It's obviously useful when working on models, but not as useful when capturing images.
    I've also used the Windows 7 built-in "Snipping Tool" to quickly capture things on the screen. I'd still like to be able to fill the graphic window, however, before making the snapshot.
    Message was edited by: aeromorrison
