May 13, 2017 12:19 PM UTC
Sir, I have creo 2.0 in which I am not able to save model in JT format. Can you help me?
    May 15, 2017 3:49 PM UTC
    1. your license must contain Interface for JT module (code 263)
    2. you have to check JT interface item during installation
    MH
    18-Opal
    May 15, 2017 5:46 PM UTC
    Hi Vaibhav,
    Did Martin's reply help you with your issue?  Do you have the license file for the JT Interface and did you check the option during install?
    Amit
    May 16, 2017 9:54 AM UTC
    If you don't have the Creo Interface for JT, you can also try CrossManager: It's a converter which can convert Creo native files to JT.
