Jan 17, 2016 10:55 PM UTC
Skeleton files, Creo3.0
Are skeleton file not used in Creo3.0? I can't find the command. Skeleton is not a keywork in serch.
    2-Explorer
    Jan 18, 2016 12:40 AM UTC
    It would be odd if it's not there. It's a subtype of part, as in New -> Part - Skeleton or Part - Bulk Item.
    Jan 18, 2016 7:40 AM UTC
    I guess skeleton model can be created in Assembly mode, only.
    MH
    Jan 18, 2016 1:51 PM UTC
    Yes, Skeleton parts can only be created within the context of an assy.  It's always been that way, I believe.
    And they are still in Creo 3, assuming you have an AAX license.
    jsawyer1-VisitorAuthor
    Jan 19, 2016 10:48 PM UTC
    Thankyou, I did find it where David said it would be. I just had a bran fart, Thanks again
    Mahesh_Sharma
    22-Sapphire I
    Mar 4, 2016 7:36 PM UTC
    James,
    You may mark David's reply to post as correct answer as that helped you
