May 19, 2015 6:58 AM UTC
Sketch view refresh problem
Hi All ,
Here is my problem,
First i will start with my pc configuration:
CPU: Athlon X4
VGA: some radeon card with 1gb DDR5
Ram: 8GB DDR3
SSD hard drive
So i am using Creo 3.0 and the problem is that when i enter the sketch and try to move the view around the planes(whit middle button of the mouse) it didnt refresh and all i see is a lot of lines. the problem exist only when i am in the sketch.
Thanks in advance and have a nice day!
May 19, 2015 8:08 AM UTC
Radoslav,
start with well known trick, add the following option at the end of config.pro file.
graphics win32_gdi
Test Creo.
Martin Hanak
Radoslav,
graphics win32_gdi
Test Creo.
Martin Hanak
May 19, 2015 7:31 PM UTC
Hi Martin,
I want to thank you, it works now everything working great !!!
Radoslav Dimitrov
May 20, 2015 4:51 AM UTC
Radoslav,
now you know that the problem is related to graphics drivers. So the next step is to remove graphics win32_gdi option from config.pro and update graphics drivers. This step enables Creo to use OPENGL graphics instead of Windows WIN32_GDI graphics.
Martin Hanak
