sketcher construction line stlye
Hi has anybody found a way to change the colour of how construction lines appear when in sketcher mode. If I draw some lines then change some to construction lines or add construction lines they both appear as yellow , this makes it very difficult sometimes to distinguish at a glance which is which. I have been on several forums including this one and have found nothing.....!! any help would be much appreciated many thanks
    Go to View -> Display Settings -> System Colors
    This is a new capability in Wildfire 4.0 http://www.ptc.com/appserver/wcms/relnotes/note.jsp?&im_dbkey=50865&icg_dbkey=826 In Wildfire 4.0 there is also a new tab in System Colors for Sketcher to allow you to set construction lines to be always a different colour
