sketcher-help
I have some problem with sketcher.please help: 1-How can I snap an end point of a line to a spline? I can only snap to lines, arcs and spline endpoints (not to the curve itself) 2-i also want to add a tangent relation between a line and a spline but I cant. (again not at the end point)
    Hi, I hv not tried this. Probably, u can create two sketches. 1. Ur spline in the first curve. 2. Take referance of this curve in the second and both ur problems may be solved.. HTH Joe
    ProMan1-VisitorAuthor
    not the second one
    Depending on what else controls your situation, there are a few ways to deal with this. For example, create the spline as a separate curve, as suggested. Then create a second curve, do a Use Edge to copy the spline, place a Sketcher Point on the curve, trim away the curve to one side of the point, then create a line tangent to the end of this second truncated version of your spline. Good luck, David
