sketcher scale
Pro E users,
Is there a way to change the sketcher scale? Upon the first sketch, if I
draw a circle, the value of the diameter
is large. My parts are less than 1 inch in diameter (most cases). I
usually create a circle, and by default the value is a couple of
hundred, then I adjust the value to 1 and delete and then begin my
sketch. Any ideas would be much appreciated.
Brad
WF 3
    Brad, To the best of my knowledge, there is not a "sketcher scale" configuration setting. The twomethods I haveused (besides manually changing every dimension in the sketch) are documented here: - Modify/Lock Scale:
    Brad,
    Sketched entities can be proportionally scaled down or scaled up and rotated or translated as below,
    >>Select all entities (sketch) that needs to be scaled
    >> select scale option from sketcher option (side to mirror option)
    >>change the scale value by decimal numbers
    [cid:image004.jpg@01C9B43C.296C9870]
    Thanks & Regards,
    Shanmugasundaram Ganesan Padayatchi
    Hi Brad,
    This was annoying for me also.
    If you zoom in approx 3 times, your scale will be around the 1 inch mark.
    OR in your start part make an extrude feature on each default datum plane that are around 1 inch in size.
    I have three features in text FRONT, RIGHT, and TOP, I delete two of them and use the other for my first feature
    Andy
    WF3.0 ( Returning user from Solidworks, Hi everybody)
    In Reply to Shanmugasundaram Ganesan:
    Apr 03, 2009 08:02 AM
    Hi Brad, I am ataching the original question (new user!!)
    Andy
    Brad,
    Thanks & Regards,
