Aug 2, 2010 3:05 PM UTC
SolidWorks to WF5
Does anyone have experience opening native SolidWorks files directlyinto Wildfire 5.0? If so:
  • Is the file parametric (can it be modified)?
  • Do properites (parameter-esk) come through?
  • Can it be save as a normal proe file?
  • Is there any special software that needs to be loaded?
Thank you,
Bob McDonald
Herman Miller Inc.
    Aug 3, 2010 2:49 PM UTC
    In Reply to Bob McDonald:
    Thank you,
    Bob McDonald
    Herman Miller Inc.
    Hi Bob,
    Here are some answers to the best of my knowledge:
    • Is the file parametric (can it be modified)? - Not parametric,use feature recognition tool to create Pro/E features.
    • Do properites (parameter-esk) come through? - Not that I'm aware of.
    • Can it be save as a normal proe file? - It will have an Import Feature as its primary feature, similar to what you would find with STEP, Parasolid and IGES.
    • Is there any special software that needs to be loaded? - You need a license for Solidworks in order for this to work. There is a "key" you need to get from Solidworks (assuming you are current on their maintenance) and you enter this key usingthe hidden config option: swdocmgr_license_key.
    Hope this helps.
    Doug
    Aug 5, 2010 2:42 PM UTC
    In Reply to Doug Hippe:
    Do you know what the name of the license key is to request from SolidWorks?
    Brian
    Thank you,
    Bob McDonald
    Herman Miller Inc.
    Hi Bob,
    Hope this helps.
    Doug
    Aug 5, 2010 3:06 PM UTC
    Brian,
    See the PTC - TPI 145366 for details.
    In this TPI it provides the email you need to send the request to and
    the specific DLL you need a key for.
    Allen Caldwell
    Manager, Product Development Center
    EAC Product Development Solutions
    1-888-225-7579 ext. 114
    Aug 5, 2010 3:23 PM UTC
    PTC call?
    Aug 5, 2010 3:32 PM UTC
    Got the needed answers,
    Thakns to all,
    Brian
