Jun 9, 2014 6:35 PM UTC
someone can repair heal the dimples that are corrupted?
Please see the attached stp file if you can.
    Jun 9, 2014 8:55 PM UTC
    I was just going to delete them all out and put them back in. But I can not figure out a simple way to get the pattern to work. Can draw in 100+ points, but that's a lot of work.
    aminhas14-AlexandriteAuthor
    Jun 9, 2014 8:58 PM UTC
    thank you but sorry I can't do that.
    Jun 9, 2014 9:32 PM UTC
    One surface is easy.
    Jun 10, 2014 6:03 AM UTC
    Adnan,
    I not experienced user in Import area, so I did simple test.
    • I opened STEP file in Notepad and looked for accuracy info ... 1.959893631850E-5
    • I created new part in Creo Parametric 2.0 M070 (in millimeters) and set minimum possible absolute accuracy 0.000073
    • I imported STEP into this part
    • result is the part containing geometry checks and a lot of inverted dimples ... see attached pictures
    Martin Hanak
    Jun 10, 2014 6:52 AM UTC
    thank you very much is that possible you will make a video?
    Jun 10, 2014 8:01 AM UTC
    Adnan,
    what do you want to see in the video ? You are not able to reproduce my procedure ? What Creo/ProE version do you use ?
    Martin Hanak
    Patriot_1776
    Jun 10, 2014 9:48 PM UTC
    I only have an older version of creo. If you have a version of Solidworks, use that to export a STEP file. Sometimes when I get vendor STEP files, I import it into Solidworks, and that usually automatically fixes it. If not, I use their version of IDD, fix as much as possible, then STEP out to Pro/E. That usually fixes most everything.
    Jun 25, 2014 9:27 PM UTC
    If I understand your problem is replacing the damaged spheres.
    It´s not difficult. Inside IDD select a good quality complete sphere (with just two surfaces), the copy it and paste special.
    Now, the transform interface appears. Select "centered" and select one of the damaged surfaces and one of the copied ones.
    This process will make a copy of a sphere and center it with the center of a damaged one. Repeat the process through all the damaged ones.
    Now delete the damaged surfaces and merge the new surfaces with the base surfaces and solidify.
    Done.
    I can make a small tutorial if you want, but not in the following days.
    Jose
    Jun 25, 2014 9:33 PM UTC
    Dear Jose,
    yes you are right. may I know when you able to make tutorial that will be very help full to me.
    thanks,
    Jun 26, 2014 4:33 PM UTC
    I have to do this in various steps.
    This first video shows how to copy the spheres and how to merge them with base surfaces.
    If you have to repeat a operation several times, use mapkeys to speed up the process like I do in the video.
    Video Link : 5087
    Let´s see if tomorrow I can do another one.
    Jose
    Jun 26, 2014 6:41 PM UTC
    Hello Jose,
    any option to download this video?
    Jun 27, 2014 8:02 PM UTC
    I don´t think so.
    Jun 30, 2014 2:08 PM UTC
    Hi, I hope you can understand the tutorial.
    I attached the .prt file
    Video Link : 5095
    Jose
    Jun 30, 2014 2:16 PM UTC
    Hello Jose,
    thanks you very much but can't fine any futures which to make?
    Jun 30, 2014 9:57 PM UTC
    What??
    Is that Google Translator?
