space ball?
Can someone explain what a space ball does for me using proe? If is really all that and a bag of chips, how do I input numbers etc?
    Is it true that WF4 can save a file out so that WF2 can open it?
    Doug
    Northrop Grumman
    Hey Doug,
    Not sure if you’d had this question answered for you but the answer is both yes and no.
    Unless you output it as an iges/step/CAD-Neutral file WF 2 cannot open a WF 4 file.
    However, if you download the Cross-Release Interoperability plug-in (from the PTC site I believe) you are able to open files in WF 2.
    The main limitation to this is the file opens up as read only – the existing features are displayed in the model tree but aren’t editable.
    For more information read up more on Cross-Release Interoperability (CRI) from the PTC website. I will try to attach the PDF with more information on it as well.
    Best Regards,
    Gabriel Mantaring
    Applications Engineer, TriStar, Inc.
    Check this TPI it may helpful
    Swamy
    Thanks to all that replied.
    I was able to install the Granite plug in without admin help. I opened
    the files and was on my way!
    Best Regards,
    Doug
    Northrop Grumman
