Spinning with multi-button mice in Wildfire
I have an Intellimouse Explorer with 5 buttons. I have set the buttons to
Ctrl and Shift in the configuration software. My issue is that Pro/E does
not recognize the buttons being pressed. The result is that I can not pan
with one hand. Any help is appreciated.
Andrew Montgomery
Designer / Engineering Systems Administrator
ph. 815-673-6048
fax 443-432-0467
Vactor / <http: www.vactor.com="/> Guzzler Manufacturing
Federal <http: www.federalsignal.com="/> Signal Corp.
