May 20, 2013 7:08 AM UTC
Spiral
I want to make a cylinder, and it has a hollow inner spiral. I can make a hollow inner spiral,but how can I make it inserted in a cylinder.
The picture shows a object, but it doesn't satisfy my requirement.I need a hollow inner spiral.
I'm a beginner to Pro/e, but I have limited time to finish thsi object. So c%E6%8D%95%E8%8E%B7.PNGan someone help me? Thanks in advance.
    May 20, 2013 2:37 PM UTC
    If I understand correctly, you want to intersect the cylinder with the spiral tube. What does the section look like if it is the way you want?
    Right now you show IO OI If you want a different section, you need to create it with a more appropriate sketch. You can also merge surfaces.
    If you can, please post a picture of what you want the final part to look like.
    Patriot_1776
    May 20, 2013 3:18 PM UTC
    Not enough info to help you. Do you want a helical coil inside a cylinder? As in some sort of heating or cooling coil inside of a vessel?
    May 22, 2013 8:39 AM UTC
    Yes, A solid cylinder inserted with a hollow helical coil.The picture shows the intersection of the coil and the cylinder is solid, I want to remove the material. Also, I want to merge the surface.
    May 22, 2013 9:00 AM UTC
    Actual I want to do this.The picture below is a coarse diagram. The black line represents a solid block, like the cylinder. The pink line represent a helical hole. It firstly spirals up then it spiral down.
    I can mkae a helical coil surface, but how do I inerset it into the cylinder, and how to merge the surface in the bottom line.Capture.PNG
    May 22, 2013 5:08 PM UTC
    You can create spirals independently and then create a sweep feature from the ends to the cylinder bottom. You can merge the faces several ways, but a simple method is to create Fill feature. If you do all this as surfaces, you can Merge all these surfaces into a quilt. Once it is one big quilt, you should have the Solidify feature available to make this a solid mass.
