Jun 28, 2011 8:06 AM UTC
Spring endurance calculation using Mechanica
I want to calculate endurance of spring in Wildfire 5.0.
I want to apply a load of 600N, strokes doesn't matter for 1 lakh cycles. The test speed is 2Hz.
Kindly suggest how to solve this in Mechanica.
Dhinesh
    Jul 12, 2011 8:13 AM UTC
    Well, Mechanica can easily calculate the stress at your maximum load, and unless it's a really big spring the dynamic load at 2 Hz can probably be neglected.
    After that, you'll need to use some fatigue data for your chosen material, and probably do some good old-fashioned maths with it...
    2-Explorer
    Jul 22, 2011 7:03 PM UTC
    Hi Dhinesh,
    It's possible that PTC's Fatigue Advisor could help you with the endurance calculations.
    Tad
    Oct 11, 2011 10:39 AM UTC
    Hi Tad,
    Anything in the pipeline for Fatigue Advisor?
    Assemblies? Load histories greater than 100 lines? Better CPU usage (only one core seems to do anything)
    Charles
