Standard Holes & DOWEL holes
Is anybody using standard holes for dowel holes ?? Standard holes are
driving by some thread, but dowel holes have no thread involved. How do you
standardize dowel holes ?
Regards, Hugo.
    Uncheck "Include thread surface" from the Shape slide-up panel in the Hole
    dashboard?
    Nicolas Hostein
    Mechanical Engineer
    BioValve Technologies
    This is not possible (WF1) of blind holes. And dowel holes are mostly
    blind.
    2/
    As for threaded holes, dowel holes are drilled upto a certain depth, and
    finished upto a depth less then the drilled depth.
    3/
    Feature Information does not identify the hole as a dowel hole, but as a
    special kind of fastener hole.
    So, this is not a decent solution.
    Regards, Hugo.
    "Nicolas Hostein" <-> wrote in message news:71366@model...
    > dashboard?
    > Nicolas Hostein
    > Mechanical Engineer
    This is what we do.
    Create a threaded hole blind and turn-off the cosmetic thread (In the Shape
    Popup, as Nicolas Hostein suggested)
    I filed an enhancement request some time ago to allow a drilled hole to be
    blind, no resolution yet.
    Thank You,
    Vaughn McDaniel III
    Mechanical Engineer
    JR Automation
    13365 Tyler
    Holland, MI 49424
    Ph 616.820.3330
    Fx 616.399.4443
