Start Pro/E with all Datums/CS/Etc off
I have a mapkey that does this, but I have a user who would prefer they are automatically off on startup.
Dave
    dbower210-MarbleAuthor
    Thanks for all the quick responses! This did the trick...
    set the following config.pro options to no
    display_axes
    display_coord_sys
    display_planes
    display_points
    Go to Tools, Options, pick the Find button, and type in display as the keyword, and pick Find Now. You will get a huge list of config options that control the display of these kinds of things. You can place these in either your load point config or your start dir config.
    You can also create config files that just have these environment settings and them make some mapkeys that load the environment you want.
    Another way is to use layers and blank all of them and do a save status,
    from that point forward when you bring up the components they will match
    whatever save status you did last.
    Brian S. Lynn
    Technical Coordinator, Product Engineering
