Starting up Pro-E with floating modules...
Is anyone aware of how to Start Pro-E and automatically have it start any of the availiable floating modules once it starts up? I'm not sure if we need to start it with a mapkey or if there is some other option availiable at startup...
Peter Woerner
Gleason Corp.
    For running Pro/E alone, can make different bat file.
    Launch ptcsetup.bat , usually under C:\ptc\proe\bin
    Check the “Additional license configurations”
    Add another configuration, by giving a “configuration name” and selecting the appropriate licenses.
    This creates a bat file pointing to a new configuration psf file.
    The bat file can be pointed to by a desktop icon whose target is the proeBase.bat
    Example:
    In ptcsetup.bat “configuration name”: proeBase
    creates a proeBase.bat file that is just 2 lines pointing to a new
    configured proeBase.psf
    Create a desktop icon whose target is the proeBase.bat
    Yet different method if you are using Pro/IntraLink
