Sep 22, 2014 8:51 PM UTC
STP/IGS Viewer?
All -
I have a user doing an offsite presentation in a few days, and we are looking for a (preferably free) model viewer so he doesn't have to deal with our VPN or logging in to Creo. I did a quick search here and see several older posts for products from eDrawings, Kubotek and Delcam - is there anything new and exciting that we should look at as well?
Thanks in advance -
Chrystal Johnstone
Seattle, WA
    TomU
    Sep 22, 2014 9:14 PM UTC
    Creo View Express is free.
    Sep 22, 2014 9:50 PM UTC
    Thanks, Tom and Steve -
    I didn't realize you could use the CreoView products independent from Creo and/or Windchill. This is perfect!
    Chrystal
    Sep 23, 2014 12:00 PM UTC
    Chrystal,
    Just be sure to check the matrix that Tom linked to. The free version has some limitations (last I knew) with what file types it can open. I believe one of either IGS or STP required an up-option, paid version. It's a good tool to work with if that limitation isn't an issue.
    Erik
    Sep 23, 2014 1:45 PM UTC
    Good point - I noticed that on the matrix; so we did try opening a .asm file, and it did just what we needed.
    Thanks again, everyone!
    Sep 23, 2014 2:14 PM UTC
    Erik is right. There are some limitations. Here's how you can use Creo View to import STP and IGS files.
    STP files - Imported in Creo View Lite and Creo View MCAD
    IGS files - Imported in Creo VIew MCAD only
    Hope this helps.
    Madhavi
