Jun 13, 2017 12:11 PM UTC
Style curves to a specific layer
I would like my style curves automatically to be included in a specific layer so they will be easy to hide. Is that possible?
Thanks in advanced.
Hans
    mkeskinenAnswer
    Jun 20, 2017 11:36 AM UTC
    Hello Hans,
    create a layer with following rule to capture curves in style features.
    BR
    Miika
    Jun 13, 2017 12:28 PM UTC
    Hans,
    You can setup a rule in Layers that will capture the Style feature but it won't differentiate between Style curves and Style surfaces.  Make sure you setup the rule by selecting the following:
    Look for: Feature
    Look by: Feature
    Attributes: Type
    Category: All
    Value: Style
    Since Style features are normally "super features" with best practice being to combine curves and surfaces created using ISDX functionality being in a single feature (allows you to dynamically update things by pushing and pulling on the curves) I don't know of any way to separate the curves from the surfaces.
    If you are creating Style curves for use with Boundary Blend surfaces (each Style curve is an individual feature in the same manner as datum curves) then this layer rule will work for you
    Mike
    mkeskinen1-VisitorAnswer
    Hello Hans,
    BR
    Miika
