summary: dec. places in a table
After the text for the parameter, you call out the number of decimal places using square brackets. Example:
&length[.4]
    That would be true if you manually put in each parameter in to the table
    but not when you use repeat regions.
    Brian S. Lynn
    CAD Administrator/Designer
    It does work with simple repeat regions. I am not sure about 2D
    Example.
    &fam.inst.param.value[.0]
    [&rpt.rel.convert[.1]]
    Luis
    I tried it this morning and couldn't get it to work, so I assumed it was
    lost in the fire.
    Brian S. Lynn
