8-Gravel
Summary - Hole Notes
It was as I feared. The only way others have found to change the note
format, was to delete, and recreate the hole.
Thanks to all who took the time to reply!
Rob Devaux
Sr. Tool Designer
ABA-PGT, Inc.
10 Gear Drive
Manchester, CT. 06042-0270
United States of America
(860)649-4591 ext. 120
fax (860)643-7619
rdevaux@abapgt.com
www.abapgt.com
    Unfortunately... they have fixed this issue in WF4. Note the 'reset'
    button in the corner. You'll still have to manually do this to each
    hole to fix it, but at least you don't have to delete and recreate...
    Tony
