SUMMARY: Hole tables in Wildfire 2.0?
Hi folks, not a lot of responses, but the few I got pretty much said the same thing. The .hol file is where to edit the standard holes. This is edited with Notepad or another text editor. Pre WF2.0 releases do not have much you can edit, but WF2.0 has much more you can edit. Some people suggested that you could edit pretty much anything you would need to. Others suggested otherwise. I received some samples that were helpful. Thanks to those who responded.
John Bettencourt
