2-Explorer
Summary: Hole through to next
Seems the answer is 'Yes, it does work, but the preview doesn't.'
So if you ignore the fact it looks as if it doesn't work, then ('usually')
it does.
Don't you just love it?
Have a good weekend.
Original message:
<<<<<<<is it=" me,=" or=" does=" the=" option=" to=" make=" a=" hole=" 'up=" to=" the=" next=" <br="/>surface' just not work?
As you can see from the pictures, the hole extends an arbitrary amount
through the next three surfaces as far as I can see.
Any suggestions?
WFII, M220
(although it has been the same ever since I went to WFII) >>>>>>>
Cheers,
    There seems to be quite a lot of areas where "preview" doesn't give you
    what you're going to get. Rounds are a lottery and the preview gives you
    no idea whether it'll be a go or no go situation. Preview is about as
    useful as an ashtray on a motor bike.
    Richard
    2-Explorer
    Well, the full preview always works as expected and I still like the
    dynamic preview since it has the handles.
    And, I saw a guy on a Harley smoking a cigarette while cruising a main
    street in northern San Diego a couple of weeks ago. I would love to see
    an ashtray on his bike so he doesn't just toss it and start a fire.
    Darren Guidry
    MCAD Systems and Design Support Supervisor
    General Atomics Aeronautical Systems, Inc.
    (858) 525-6668
    JWayman2-ExplorerAuthor
    2-Explorer
    Original Question:
    Is it me, or does the option to make a hole 'up to the next surface' just
    not work?
    Any suggestions?
    WFII, M220
    Answer:
    Seems it was me a bit...
    I made the mistake of believing what I saw during the preview. That is the
    bit that doesn't work. When you ignore the preview and click the tick it
    makes a hole through to the next surface, just as I wanted.
    I expect it will be fixed one day.
    Thanks to all who replied.
