Summary - Intent edges?
We have a winner - if I don't use my start parts, then it works. Now all I have to do is redo my start parts.
The answer came from -H.SaldanaI remember some time back when the intent option came out
(200i^2) I noticed that some parts did not have the option while others
did. After probing a bit more the only correlation I made was that the
parts that were started in 200i^2 (w/ 200i^2 start parts) had the option but
parts that were started prior to 200i^2 did not. We were using start
parts that we carried over from rev 20 and even those parts did not have the
intent option. I don’t know if this may the same issue or not but
check the audit trail on the parts.
    Actually, I think if you force a regen of your start part with the model player, it will then work. I seem to recall that was the way to sort of reset old parts to allow intent edges.
    Doug Schaefer
