Summary: Restricting Access
Make sure the "NO-ACCESS" role on the folder actions tab does not have the
"view-object" box checked. Make sure this role as assigned to the folder,
not the release levels. He will still see the folders, but won't be able to
see the objects in the folders.
This is exactly what was needed to do! Thanks to all who applied!
Dave
    Try this, the folders he shouldn't see, don't add his group
    Michelle McMasters
    Engineering Systems Administrator
    Black & Decker Hardware & Home Improvement
    michelle.mcmasters@bdhhi.com
    IMPORTANT NOTICE: This message is intended only for the use of the
    individual or entity to which it is addressed. The message may contain
    information that is privileged, confidential and exempt from disclosure
    under applicable law. If you are not the intended recipient, you are
    notified that any dissemination, distribution or copying of this
    communication is prohibited. If you have received this communication in
    error, please notify the sender immediately. Thank you.
