Summary : Visible lines in ISO view
Pro-Gurus,
I created an extruded cut to "hollow" out the label, which was simply an
extruded protrusion before. Problem solved. Thanks to all that replied.
Nick
    Just make a thru all cut in the identification label that is the same
    size as the ribbon cable going through it and all will be fine.
    Bob
