Suppress import geometry check errors?
Good morning all,
Is there a way to suppress geometry check errors you get when
opening/importing a neutral (stp, iges) file?
Matt
Matt Gortner | Mechanical Engineer
CHASEDESIGN, LLC
1400 East Genesee Street | Skaneateles N.Y. 13152
315.685.1000 (p) | 315.685.5021 (f) | www.chasedesign.net
    Hi Matt
    Set config.pro option: show_geom_checks_on_creation no
    It will import without stopping at every error.
    Bjarne
    "Matt R. Gortner" <->
    08-09-2009 16:19
    Please respond to
    To
    cc
    Subject
    [proecad] - Suppress import geometry check errors?
    Good morning all,
    Matt
    CHASEDESIGN, LLC
    -----End Original Message-----
    MGortner1-VisitorAuthor
    Thanks. That does the trick. Previously, I saw that config option but
    mistakenly thought I already had it set to no.
    -Matt
