switch between engish and metric
I our current 2d cad system we can easily add a metric value (like diameter) into a engish unit file just typing a unit symbel in after the number. example: 20mm Is there an easy way to do this in Pro/e besides / or * by 25.4?
    open the dwg that you're working on. right click- properties- drawing opt- dual dimension- check primer unite. Pro/e wil add the si unit under the us unit for you. don't have to do it by hand. good luck
