Switch off Geom Tol Datums
Hi all,
Can anyone help me to switch off Geom Tol datums ?
If i switch off planes other planes gets switched off, but not the Geom Tol
planes.
Thanks in advance.
Ram
    Ram,
    What we do here is place them on a rule based layer so that every time
    one is created it will automatically get place there. Then the user can
    turn them on or off when they need to.
    Chris Bennett
    CAD Specialist
    Stryker Instruments
    269-323-7700 x 4012
    Chris.Bennett@stryker.com
    _____
    Dear Ram Das
    When u want to switch off Geometric planes,
    You have two options:
    make a layer named as u wish, then add item to the layer by pressing + symbol,
    select feature option, in this option select All Of Type, then tick in Datum planes box.
    Done,Done,Done.
    Select that layer and switch off, all planes including geom. Planes will also switch off.
    B.If u want to switch off only geom. Planes then-
    select feature option and all Geom. planes, and switch off the layer.
    Regards
    Vivekanand Prasad
    Sr.Design Engg.
    SPHINX WORLDBIZ LIMITED
    A-27C,Sector -16
    NOIDA,INDIA
    Ram Das <-> wrote: Hi all,
    If i switch off planes other planes gets switched off, but not the Geom Tol planes.
    Thanks in advance.
    Ram
    --- You are currently subscribed to model. To unsubscribe send a blank e-mail to -. For assistance, email us at - or find other contacts at www.ptcuser.org/org/contacts.html. PTC/USER and the PTC/USER logo are registered trademarks of PTC/USER, Inc. Pro/ENGINEER is a registered trademark of PTC. Message authors are solely responsible for the content of their posts.
    Send instant messages to your online friends http://in.messenger.yahoo.com
    Stay connected with your friends even when away from PC. Link: http://in.mobile.yahoo.com/new/messenger/
