8-Gravel
Mar 9, 2011 6:07 PM UTC
Symbol in model tree while in NC
Afternoon All,
Has anyone run across the vertical black line symbol, shown below, while
in NC?
The sequence is completely defined and the play path looks good. Anyone
have a clue what this symbol is indicating?
Brian
    bparrish8-GravelAuthor
    8-Gravel
    Mar 9, 2011 6:44 PM UTC
    I found the issue. A reference in the volume definition was causing the
    issue. Not sure what the symbol means exactly, but it was present in
    the volume sketch also. Once the reference was cleaned up the symbol
    went away.
    Have a good day
    Brian
    TomU
    Mar 9, 2011 7:18 PM UTC
    It looks a lot like the "packaged" icon you get when something isn't
    fully constrained.
    TomU
    Mar 9, 2011 7:24 PM UTC
    It looks like the "packaged" icon you get when something isn't fully
    constrained. If you look at the pictures below you will see detail 502
    has a single rectangle. This item is only partially constrained in its
    assembly. Below that you will see two features (SB1_S1 and SB1_S2) that
    have double rectangles. These are features in another model that
    reference the partially constrained detail (502). The double rectangles
    help you know that something that these features are referencing is not
    fully constrained.
    Tom
    Mar 10, 2011 10:22 AM UTC
    Parallel lines plus a small hollow square icon is saying that the component is assembled by referencing a frozen component.
