System Color Scheme - Default distant light location
Question,
Can you store the light location in the color scheme you load by default? I don't see any options for it in the .scl file.
If you look at the Pre-Wildfire color scheme. The position of the Default Distant light is different than in the Wildfire color scheme. The Wildfire color scheme has the light higher and farther to the right.
WF Pre WF
X = .174 .113
Y = .451 .047
Z = .729 .866
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
