Table Defaults
How do I set default values for tables. example I can highligh the whole, click on text style set color to green. hit apply. when i go to a cell and type in a value it returns it as bluje text.
    I hope u use Creo, if so go to anotation menu in drawing then on the right ribbon there is a format sub menu, choose manage styles and change the default style.
    You could try to go to file, drawing options. there you will find a lot of options to set your values for text & many other things.
    thank you!
