Jan 20, 2006 1:45 AM UTC
Table Text Style
Guru's,
How do you set a text style to be a default style in a table? I am
editing our revision block by inserting rows. When I insert a row the
text-style does not reflect (or copy) the row before it, but rather uses
the default text style at the time the table was created? Which would be
okay except the justification is different from cell to cell. How do you
tell the table to use a set text style when inserting new rows? By the
way, I am not using repeat regions...just text.
Using Wildfire 1.
Eric
    Aug 6, 2012 2:46 PM UTC
    Anyone have a solution to this? Using WF4 and Creo 2.0
    Should be fairly simple, insert a row into a drawing table. Where do you set the default text style, or get it to copy from the row before?
    In Reply to Eric Huffman:
    Guru's,
    Using Wildfire 1.
    Eric
    May 9, 2017 3:37 PM UTC
    make_parameters_from_fmt_tables (yes) in config.pro WF 2.0
