Aug 22, 2012 3:36 PM UTC
tapped hole note display
In Creo 1 m30; How do you get the standard tapped hole notes to show up on in the model?
I've got the "Annotation Display" icon selected on the view tab but, they don't show up. Isn't that what controls them?
The notes will only appear when I pick the hole note from the model tree AND THEN spin the model slightly, after which the note will disappear.
What I'm I missing?
Tracy Willis
Designer - Document Control
COOK Incorporated
P.O. Box 489
Bloomington, IN 47402-0489 U.S.A.
(812) 339-2235 ext. 107351
    Nov 28, 2012 10:23 AM UTC
    HelloTracy Willis,
    When you are take hole tool. in that tool there is a placement pannel name PLACEMENT,SHAPE,PROPERTY,NOTE..
    Just see into the Note, in note just check it if there is a mark on ADD NOTE.
    if not then mark on that and see it is visual or not..
    Ujas Suthar
