Text and arrow size
I wanted to know how to change the text and arrow size for all dwgs?
    Change Your Configuration Options
    Aaron, For drawing specific options such as text height and arrow size, its a nested process. These settings are not regular config settings, but Drawing Options (File/Properties/Drawing Options). Here you will find choices like drawing_text_height. Set your preferences, then Save the file. Now use the config option drawing_setup_file to set the path/filename so that these settings will be loaded when you start Pro. You can also set the option pro_dtl_setup_dir. David
