Text in the model view?
Hi I want to put a Note on a Model,but would like it to be always facing forward,even if you orbit the model. Is this at all possible Thanx Rene
    Hi Rene, When you create a note by #Edit >> Setup >> Notes >> New ; you have a checkbox to place the note parallel to screen. You just need to check the option 'Place note flat to screen'. You can modify existing notes too. Rameet
    Rameet Thank you That's exactly what I was looking for Cheers
