May 17, 2016 12:57 PM UTC
Text of the sections' notes
Hi all,
I wonder if there are the options to edit automatically the text of the sections' notes within the drw.
I would need a text like the bottom one, instead now I have the top one.
Thanks.
Bye
    May 18, 2016 6:22 AM UTC
    Creo provides 2 drawing options related to drawing view notes, only.
    view_note std_din
    • removes SECTION from view note text
    def_view_text_height height
    • sets text height
    MH
    May 19, 2016 2:50 PM UTC
    After you edited 1st section note, you select 2nd note and then click Repeat Last Format, or Properties -> Text Style -> Existing Text: Select Text (to select 1st section note)
