Textures / jpegs on multiple surfaces
When I use a jpeg as a texture/decal, the image is repeated is you
select multiple surfaces. Is there a way to get this image to span the
gap between surfaces (let's assume they're tangent surfaces)?
I can "cheat" by mapping the 2 surfaces separately and moving/distorting
the image, but that's not ideal.
Matt Gortner
CHASEDESIGN
    MGortner1-VisitorAuthor
    And the answer I got from a few people was: "The mapping type by default
    is parametric. For your requirement you may have to change the mapping
    type to any one of the following Planar, Cylindrical or spherical from
    Appearance Placement Editor."
