Dec 10, 2015 1:59 PM UTC
The value for MASS_GR cannot be changed
A user is receiving the following error.  "The value for MASS_GR cannot be changed".   The material properties have the correct units and agree with the standards we apply. Any thoughts of what could be the issue? Thanks  CREO2 m120 ~ Windchill 10 m20
    Mahesh_Sharma
    22-Sapphire I
    Dec 10, 2015 6:23 PM UTC
    Tim,
    Parameter Mass_GR is relation based.
    Try updating mass properties using File > Prepare > Change Mass properties > Generate report and try Save and upload.
    This is all about Creo, not sure about Windchill as Windchill is out of my expertise.
    Dec 10, 2015 2:29 PM UTC
    what action is user doing ?
    MH
    tperry1-VisitorAuthor
    Dec 10, 2015 6:04 PM UTC
    -        He is checking-out the drawing and part from Windchill.
    -        Delete the model from the .prt file
    -        Append a step into the same .prt file
    -        Assign new material from a library
    -        Model check, to assign missing tolerance, and various notes.
    -        Save and upload
                  o   Failed upload:   “The value for MASS_GR cannot be changed” shows at this point
    Note:
    -        We have made sure the material properties agree with standard before and after error.    (Millimeter kilogram second)
    -        The material library is our standard and has been viewed for proper units, in the event units was recently changed.
    -        Even “save and upload” as checked-out, with no changes results in the same upload error.
    Hopefully this offers some good information , and I appreciate your help.
    Kind regards,
    Tim
    Mahesh_Sharma
    22-Sapphire I
    Dec 10, 2015 5:09 PM UTC
    Tim,
    Is it in all of the files or data specific? Can you upload a sample file to look?
    Dec 10, 2015 6:13 PM UTC
    See attached for the .prt file
    Mahesh_Sharma
    22-Sapphire I
    Tim,
