Oct 20, 2015 9:17 AM UTC
threated holes with creo
an easy way to make threated holes (3/8" BSP or GAS). what does it mean UNF and UNC close to ISO and values like7/8-14? thanks for help
    Oct 20, 2015 2:19 PM UTC
    UNF is Unified Fine
    UNC is Unified Course
    See this wiki page: Unified Thread Standard - Wikipedia, the free encyclopedia
    7/8-14 is a .875 inch outside diameter with a 14 threads (pitch) per inch.
    ISO threads are the same way: 6-.0.75  is a 6mm outer diameter with a 0.75 pitch for the thread spacing.
    You can create your own thread (.hol) files by following the setup of an existing file.
