Tieing a symbol to a table on a format
I'm wondering if you can tie a symbol to atable on a format. My example is that I have a triangle symbol in a table square, and sometimes I need to make the height of the table increase and I want the triangle symbols to move with the tables.
Thank you,
Brian Toussaint
    That would be nice.
    Our drawing symbols (hexagons, flags, etc.) are placed in a
    "floating" manner with respect to the drawing table cell (e.g. they look
    like they're in the table itself) that they should be inserted in. When
    the table updates (rows reordered, rows added, rows removed, etc.)
    those drawing symbols often have to be repositioned.
    I'm not aware of a method that will allow drawing symbols to be placed
    directly in the table itself via a parametric call (e.g. &SOME_SYMBOL)
    or otherwise "relate" drawing symbols to drawing tables like what can be
    done with draft entities and drawing views. I'm pretty sure that drawing
    tables can't be included in draft groups.
    Maybe someone else has a rabbit to pull ...
    Dustin Neifer
    General Dynamics Land Systems
    "Brian Toussaint" <->
    10/10/2007 10:17 AM
    Please respond to
    To
    cc
    Subject
    [proecad] - Tieing a symbol to a table on a format
    I'm wondering if you can tie a symbol to a table on a format. My example
    Thank you,
    Brian Toussaint
    This is an e-mail from General Dynamics Land Systems. It is for the intended recipient only and may contain confidential and privileged information. No one else may read, print, store, copy, forward or act in reliance on it or its attachments. If you are not the intended recipient, please return this message to the sender and delete the message and any attachments from your computer. Your cooperation is appreciated.
    From the Pro/E r20 manual :
    Adding Drawing Symbols
    You can include a drawing symbol in a note if its instance is present
    in the drawing. To include a symbol, use the following format:
    &sym(<symbolname>)
    Type the symbol filename without an extension. For example, if a
    drawing contains an instance of the symbol "bevel," to include the
    symbol in a note, type [&sym(bevel)].
    Note: Drawing symbols cannot be called out in dimensions.
    When you include an instance of a generic symbol, after you type
    the symbol name, select groups that compose the instance (this is
    similar to creating instances of a generic symbol). For more
    information on symbols, see the chapter Symbols.
    When you edit a note using the Full Note or Text Line commands,
    the system represents the symbol in the following format:
    n:&sym(sym_path)
    where "n" is the number of the text element, and "sym_path" is the
    name or pathname of the symbol.
    Here is the summary for what I was asking to do.
    Since I want variable text in the symbol, I needed to create a symbol
    that had variable text. Then to add a symbol in a table square you type
    in text in the format of &sym(symbol_name).
    Thank you to all that helped.
    Sincerely,
    Brian Toussaint
    CAD Administrator
    618 Hwy. 74 S., Peachtree City, GA 30269
