Apr 8, 2014 5:07 AM UTC
tiresome process of making slots
Is there any easier way to make slots rather than joining two circles with two tangent lines
Regards
samuel
    cgungorAnswer
    Apr 8, 2014 5:22 AM UTC
    While you are in the sketcher mode: Sketch>Data from File> Palette> shapes>racetrack. Drag and drop the racetrack into the graphic area. Then modify dimensions according to your needs.
    Celalettin
    cgungor1-VisitorAnswer
    Celalettin
    Apr 8, 2014 9:04 AM UTC
    I added many sketches to the sketcher palette I'd like to use more often.
    Of course there isnt a "add sketch to palette" button in Creo because that would be easy.
    You can backup the sketch of your slot to the sketcher pallete (just search for "sketcher_palette" directory on your harddrive), you can also place your own sketches in a subfolder in "sketcher_palette" which will then appear as a new tab in the little Palette window.
    You can also manually set the directory in config.pro using the setting "2d_palette_path".
