Dale_Rosema
Mar 10, 2015 8:05 PM UTC
"&todays_date"
I have a table that I have been using that has "&todays_date" which has been working well and shows the date as 10-MAR-15.
I copied this table over to another table, but similar and when I go to use this new table with "&todays_date" it works also, but shows the date as Mar-10-15.
How do I fixed the format of the date when they are both "&todays_date"
Thanks, Dale
    Dale_Rosema
    Mar 10, 2015 8:47 PM UTC
    Tom,
    %dd-%MM-%yy
    This was tucked away in some obscure place of an old mapkey. During revisions recently it got removed.
    Now it has been added back in and the date works correctly for either table.
    TomU
    Mar 10, 2015 8:22 PM UTC
    config.pro option "todays_date_note_format". We have ours set to: %mm-%dd-%yy
    Dale_Rosema
    Mar 10, 2015 8:42 PM UTC
    ... and what does that give you Tom?
    Mar-09-15
    If I want 09-MAR-15, do I use %dd-%MM-%yy?
    Thanks, Dale
    Dale_Rosema
    Dale_Rosema23-Emerald IVAuthorAnswer
    Tom,
    %dd-%MM-%yy
