Jul 17, 2014 1:00 AM UTC
traceback.log
Unfortunately, my application crashes on a customers computer and a
traceback.log file is generated.
The following is the beginning of the traceback.log file:
    Jul 17, 2014 5:53 AM UTC
    Hi Bob
    Could the difference in traceback.log be a matter of debug/release versions of your program or that you have the Visual Studio environment on your developer machine.
    The given log seems to reference memory space with no link to code line numbers.
    /Bjarne
    BobMonat1-VisitorAuthor
    Jul 17, 2014 11:11 PM UTC
    Bjarne,
    I used a debug build. In the C/C++ Generic, I set Debug Information Format
    to Zi. In the Preprocessor symbols, neither _DEBUG nor NDEBUG was set. In
    the Linker Debugging, I set Generate Debug Info to Yes. These are the
    settings I had used successfully on a development machine.
    Bob
    Bob Monat
    Jerand Technical Services, Inc.
    bob@jerand.com
    www.jerand.com
    1-317-875-6087
    On Thu, Jul 17, 2014 at 1:53 AM, Bjarne Frandsen <->
    wrote:
    > Hi Bob
    > numbers.
    > /Bjarne
    > *From:* - [
