Nov 23, 2010 9:40 AM UTC
trail file
wat is use of trail.txt file?
    Nov 23, 2010 10:19 AM UTC
    Trail file serves as a backup file into which entered all the steps in defining objects in Creo Elements/Pro (formerly Pro|ENGINEER)
    If the user makes a mistake in modeling and closes the program, does not have to click all the steps again.
    Sufficient if run trail file to create previous steps.
    Nov 24, 2010 6:29 AM UTC
    can u explain me how to backup part if i lost my part.
    Nov 24, 2010 1:23 PM UTC
    If you have trail file for your lost part you can:
    rename trail file: trail.txt.29 to (anyname.txt) as lost_part.txt
    Start ProE > select: Tools > Play Trail/Training File... and select renamed file.
    Then the system starts to load steps of the trail file.
    Dec 7, 2010 8:30 PM UTC
    One more suggestion/caution about the use of trail files. Sometimes you use them to recover from an unexpected crash long after your last save. IF this crash was caused by your last action within Pro (as rare as that may be), then you want to delete the last little bit of the trail file before running it, or you will just crash again.
    Dec 7, 2010 8:36 PM UTC
    Good addition David for all those new users and seasoned veterans that might not have known that!
    Best!
    Bob
