Dec 14, 2010 1:08 PM UTC
transforming topographic points to solid
What's the fastest way to transform points read by a topographic station to a solid (a concrete/metal structure of a building)? (pro/e WF4)
thanks
    Dec 15, 2010 8:51 AM UTC
    Hi
    With EFX you can create metal beams from point to point. But for concrete I really do not know.
    Just telling you the way I should begin.
    Hopes this helps you to start.
    Season's greetings
    Chris
    Jan 12, 2011 11:43 PM UTC
    The Reverse Engineering Extension likley has to tools you need,,,
    http://www.ptc.com/products/creo-elements-pro/reverse-engineering
    This module is intended for use with point scans.
