Truncated Diameter Dimensioning - Is There A Simple Method?
- 3 replies
- 4346 views
- Translate All
Is there an easier method of producing truncated Diameter Dimensions as shown in the attached screenshot?
I currently use Creo Elements/Pro 5.0 and I find producing Truncated Diameter Dimensions quite time consuming,
when shown in a Detail View, where the Axes of the Diameter to be dimensioned cannot be shown as it is outside the boundary of the Detail View.
At present I have to make the Detail View Boundary large eneough so that the relevant Axes can be 'Shown', then dimemsion the necessary Diameter(s), then re-size the boundary again to reduce the size of the Detail View Boundary, and then finally erasing the witness line I don't want to show.
Hopefully there is a much simpler method than this, that someone kknows of, as I find this method really painful
