Dec 13, 2010 8:10 PM UTC
Tweak Replace?
Way back before the Wildfire interface there was a command called tweak replace.
Anyone know what that called now and how to do it?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
    Dec 13, 2010 8:23 PM UTC
    David,
    Its under Edit, Offset. Pick your surface, Edit, Offset. In the dashboard change the icon to the one that says Replace if my memory serves me correctly.
    Mike
    Dec 13, 2010 8:25 PM UTC
    It's a subset of the offset tool.  Grab the surface you want to replace
    and select edit -> offset.  Then, on the offset dashboard, click on the
    icon at the far left.  A dropdown menu will appear and replace is the
    bottom pick, I believe.
    Doug Schaefer
    Dec 13, 2010 8:45 PM UTC
    Replace is also in the right-click menu when you’re in the Edit -> Offset command. Faster for me than figuring out which icon is Replace in the dashboard (but Doug’s right, it is the bottom one).
    Nate Venskytis
    Product Development
    Schick/Wilkinson Sword
    An Energizer Company
    10 Leighton Road Milford, CT 06460
    Tel 203 882 2154 • Fax 203 882 2548
    Dec 14, 2010 2:17 PM UTC
    Don't forget about the menu mapper on ptc.com to determine unfamiliar menu picks: http://www.ptc.com/community/proewf2/menu_mapper/en/index.htm
    Although Creo Elements/Pro 5.0 is not fully mapped yet, if you map from previous versions to WIldfire 4.0 with the exception for detailing, you should see the correct picks for CE/Pro 5.0.
