Unbalance evaluation
Hi guys, I have a wheel bearing drawn in Pro/E. Does anybody knows how to evaluate the unbalance in [g*mm] ? Thanks!
    PARLI ITALIANO??SE IL TUO ROBLEMA E CONVERTIRE LE MISURE IN UN TUO SISTEMA DI UNITA' DI MISURA VAI SU EDIT,SETUP,UNITS,NEW E SELEZIONA LE UNITA' PER LE GRANDEZZE DA SCEGLIERE..QUINDI ALLA FINE SET E DAI OK...SE VUOI CAMBIARE LA CONFIGURAZIONE CON UN ALTRA GIA' ESISTENTE, LA SELEZIONI E CLICCA SU SET..SCEGLI LA SECONDA CONVERSIONE CHE TI PROPONE.CIOE' QUELLA DOVE TI LASCIA IL VALORE NUMERICO..SPERO DI ESSERTI STATO UTILE
